LarsBirger
How do I perform a Cox proportional hazard analysis?
In Sweden I seem to be the only person who uses the excellent statistical software JMP. I have used it for several years and now have version 14.2.0. The majority of the research colleagues that I work with use SPSS but I think JMP is much better. However, since I am a surgeon my statistical knowledge is somewhat limited. I know JMP fairly well but I mostly do univariate and multivariate analyses of nominal data. However, now I got a question from a journal regarding the Cox proportional hazard analysis of the data. Since I do not know how to do that in JMP I would appreciate if the community could help me. The dependent (y) variabel is continuous and is time to event (in bold, see a small sample below). To the left (in italic and book antiqua) are the x variables as nominal values and to the right of the y variabel are the x variables converted to numerical (1 or 0) values where 1 is a "positive event" and 0 is the reference.
I wonder how I do in JMP to get the results of these sample data (these are just examples and not the real data) and I would like to be able to present it like below. I would prefer an instruction of how to do it in an interactive mode. However, if possible also in a scripting answer. My knowledge of how to use JMP regarding programming is somewhat better than my statistical knowledge.
Univariable analysis
Multivariable analysis
Hazard ratio (95% confidence interval)
p
p
Hilar stricture (Reference non-hilar)
0.00 (0.00-0.00)
0.00 (0.00-0.00)
Male (Reference Female)
0.00 (0.00-0.00)
0.00 (0.00-0.00)
Age ≥ 75 years (Reference <75 years)
0.00 (0.00-0.00)
0.00 (0.00-0.00)
ASA III-IV (reference ASA I-II)
0.00 (0.00-0.00)
0.00 (0.00-0.00)
Below is the example file:
Hilar stenosisGenderAge ≥ 75 yearsASA III-IVTime to eventHilar structure (GS) Yes=1 No=0Men (GS) Male=1 Female=0Age ≥ 75 years =1 else 0ASA III-IV=1 else 0
NoMaleNoNo1150100
NoFemaleYesNo1570010
NoFemaleNoYes1010001
NoFemaleYesYes1380011
NoFemaleYesNo1140010
NoFemaleNoYes1770001
NoFemaleNoNo1330000
NoFemaleYesNo390010
YesMaleYesYes291111
YesFemaleYesYes71011
NoFemaleYesNo1560010
YesFemaleYesYes1691011
NoFemaleNoNo8940000
YesFemaleYesNo3031010
YesMaleNoYes791101
NoFemaleYesYes320011
NoFemaleNoNo2110000
YesMaleNoYes2481101
NoFemaleYesYes2520011
NoMaleNoYes4560101
Of JSL code I have no knowledge.
Sincerely yours
Lars Enochsson
Professor of Surgery
Umeå University
Sweden
Re: How do I perform a Cox proportional hazard analysis?
Cox Proportional Hazards Model is available under the Fit Model Platform.  Here is a link to the JMP Help on it.
