HarriBradbeer
How do I name data table after a cell value
I have a simple script that combines relevant columns from two data sets, matching by data.
For each batch of data, the column Date contains the same value in every row.
My script includes:
              Output Table( "Data 1 and 2"))
How would I append a value from the Date column in front of the string, so that the table becomes, for example, "23.09.20 Data 1 and 2".
Thank you.
Re: How do I name data table after a cell value
One way to achieve what you're after may be to first capture the value of the date from one of the tables in a separate variable:
dt=data table ("Name of First Table");
date=Format(Column(dt,"Name of Date Column")[1],"dd.mm.yyy");
After the join, you can rename the table using the "set name" argument:
joined_table=dt<<join(...);
joined_table<<set name(date || " Date 1 and 2");
Please try that and let us know if it works for you.
Here is an example of how to do this
names default to here(1);
dt = open("$SAMPLE_DATA/big class.jmp");
dt << set name("Data 1 and 2");
// Create a Date column;()
dt << new column("Date", formula(today()),format("m/d/y"));
// Rename the data table
dt << set name(char(month(:Date[1])) || "." || char(day(:date[1])) ||
     "." || char(year(:Date[1])) || " " || char(dt << get name) );
