Hello - I know you can make non-linear custom DoEs. However, I can't seem to find a source, even a theoretical discussion in a journal article, that shows how to handle a sort of hybrid model, wherein there is a physical model that is known that relates a response with one of the factors being studied, but the model does not incorporate other factors that are under study and known to affect the system.
In my case, we have the model Y1 = q*K*X1/(1+K*X1), where
Y1 is a continuous response,
X1 is a continuous factor,
q and K are parameters.
q and K are themselves unknown continuous functions of a second factor, X2, making Y1 also a function of X2. Finally, Y1 is also an unknown function of continuous factor X3 and of categorical factor X4.
Right now we simply doing a RSM for Y1 = f(X1,X2,X3,X4), and then fitting the nonlinear model described above to the partial derivative of the RSM model with respect to X1. This seems laborious, seriously error prone, and very inefficient. However, I can't find literature on what combining physical models with factorial/quadratic models would look like, especially with regard to interactions and such. I'm but a humble chemical engineer, so I likely just don't know where to look, as I can't imagine this problem hasn't come up before.
Does anyone know a solution to this, either implemented in JMP in a sub-menu where I haven't seen it, or a literature source that I could work off of?
Thanks in advance.
(PS. It says to include if I want scripting or not. I don't know JMP scripting, so I would prefer an interactive solution. However, if there is a solution, and it would only work with scripting, I know people that could help me with that. So scripting is not preferred, but ok if its the best option. Thanks!)
Edward Hamer Chandler, Jr.
