How do I look for a blank cell with an if statement?
Does anyone know if there's a way of assigning a blank cell in an if statement?
I want to make a column with a formula that either uses the value from column 2, if one exists, or the value from column 1 if the cell in column 2 is blank. I tried to achieve this using the following formula for column 3:
If( :Column 2 > 0,
:Column 2,
:Column 1
but if column 2 doesn't contain a number then the resulting cell in column 3 is blank (see table below). Is there any way around this without assigning the missing values in column 2 as a number?
I'd be grateful of any suggestions.
Steph
Column 1Column 2Column 3
122
2
3
433
52
2
ron_horne
Re: How do I look for a blank cell with an if statement?
hi stephaniejlucas​
try ismissing (:column)
ron_horne
hi stephaniejlucas​
Thank you!
Kevin_Anderson
And if you ever need to find one, it can be handy to remember that a missing character value can be thought of as a string of zero length.  In other words, where :CharColumn == "".
Thank you!
