  • See how to interactively organize and restructure data for analysis. Register for May 29 webinar, 2pm US ET.
Steven_Moore
Missing Values/Calculations
I have a data table in which I want to add the row values of four columns into a fifth column.  However, I have missing values in all four original columns and that is OK, but when I apply the formula to add the four columns, all I get is a column of missing values because JMP will not add three values and a missing value.  What can I do to remedy this situation?
Steve
mwechtal
Re: Missing Values/Calculations
If you use the SUM function instead of the + operator, it should add the non-missing values.
Kevin_Anderson
Instead of using the + operator, try the Sum(:Col1, :Col2, :Col3) function.
ron_horne
hi smoore2
try using the sum function instead of adding.
ron
mwechtal
