Zahzul
How do I input a variable into "Historical Data End at Row" option for Multivariate Control Chart in JSL?
Hello.
This is taken from one of the Scripting Index script.
I was trying to write a JSL that essentially will have row_end as a dynamic input, but my current code below wouldn't work as intended.
How do I write it so that it can work? I've tried putting the whole expression into Eval (Eval Parse(Expression)) but that also did not work.
If I replace row_end with it's actual value, only then will my code work. Any ideas? Thanks.
I'm using JMP16.
dt = Open( "$SAMPLE_DATA/Quality Control/Flight Delays.jmp" );
row_end = 16;
obj = dt << Model Driven Multivariate Control Chart( Process( :AA, :CO, :DL, :F9, :FL, :NW, :UA, :US, :WN ), Historical Data End at Row( row_end ) );
Re: How do I input a variable into "Historical Data End at Row" option for Multivariate Control Chart in JSL?
The "Historical Data End at Row()" appears to not be able to evaluate a variable. Therefore, one needs to handle that in JSL.  A common way to do that is to use "Eval Insert()".
row_end = 16;
Eval(
	Parse(
		Eval Insert(
			"obj = dt << Model Driven Multivariate Control Chart( Process( :AA, :CO, :DL, :F9, :FL, :NW, :UA, :US, :WN ), Historical Data End at Row( ^row_end^ ))"
Or, one could use a Substitute() function to handle the issue
row_end = 16;
Eval(
	Substitute(
			Expr(
					Historical Data End at Row( theEnd )
		Expr( theEnd ), row_end
