Jiaxiang
How do I get the file names with a specific suffix from a folder?
I am trying to import some data from a folder, it contains different type of files, and I just want the file with *.s2p suffix, how can I  get all the filename with  .s2p  suffix?  I use files in directory function, but it can only get all the filename.
fileNames = Files In Directory( directory );
Re: How do I get the file names with a specific suffix from a folder?
You could try using Multiple File Import found from File / Import Multiple Files...
or loop over the list you have while filtering out non-wanted results.
fileNames = {"test0.s2p", "test.jmp", "test1.jsl", "test2.s2p"};
suffix_of_interest = ".s2p";
//JMP16
files_of_interest = Filter Each({val}, fileNames, Ends With(val, suffix_of_interest));
show(files_of_interest);
//earlier
files_of_interest2 = {};
For(i = 1, i <= N Items(fileNames), i++,
	val = fileNames[i];
	If(Ends With(val, suffix_of_interest),
		Insert Into(files_of_interest2, val);
show(files_of_interest2);
Craige_Hales
Nice! Now I need to go read about Filter Each:
Filter Each for JMP 16 in Help->Scripting IndexFilter Each for JMP 16 in Help->Scripting Index
The scripting index has three examples; the Associative Array example is in the picture. I like  @jthi  example because it hints that the expression for selecting items can be more complicated.
Craige
