I was able to add the gradient as a background image, and then overlayed data on top of it. I am using the .jpg that you supplied. You would need to create a separate image. I believe that it could be build using a graph box() in JMP.
Here is the JSL
dt = New Table( "example",
Add Rows( 7 ),
New Column( "x",
Numeric,
"Continuous",
Format( "Best", 12 ),
Set Values( [0.655, 0.655, 0.655, 1.69, 1.69, 2.715, 2.715] ),
Set Display Width( 38 )
New Column( "y",
Numeric,
"Continuous",
Set Values( [9.65, 5.6, 1.52, 5.6, 1.52, 5.6, 1.52] ),
Set Display Width( 72 )
New Column( "size",
Numeric,
"Continuous",
Set Values( [20, 20, 20, 20, 20, 20, 20] )
Set Row States( [8192, 8384, 8384, 8384, 8384, 8384, 8384] )
op = Graph Builder(
Size( 1120, 456 ),
Variables( X( :x ), Y( :y ), Size( :size ) ),
Elements( Points( X, Y, Legend( 7 ) ) ),
Dispatch( {}, "x", ScaleBox, {Min( 0.15 ), Max( 3.2 ), Inc( 0.5 ), Minor Ticks( 1 )} ),
Dispatch(
"y",
ScaleBox,
{Min( -0.635918367346939 ), Max( 11.6721345272803 ), Inc( 2 ), Minor Ticks( 1 )}
Dispatch( {}, "400", LegendBox, {Legend Position( {7, [-1, -1]} )} )
opr1 = op << report;
opr2 = opr1 << Clone Box;
opr1 << append( opr2 );
fb1 = opr1[Frame Box( 1 )];
fb1 << Add Image(
Open( Convert File Path( "<path to the image>.jpg" ) ),
Transparency( 0.9 ),
Bounds(
Left( 0.135416666666667 ),
Right( 3.26041666666667 ),
Top( 11.8333333333333 ),
Bottom( -1 )
SetSize( {300, 210} )
fb1 << Copy Picture;
fb2 = opr2[Frame Box( 1 )];
fb2 << Paste Background Image;
