Sandra233
How do I get Formula of calculate quantile spec limits in process capability
I do distributions analysis in jmp pro.18 with fit smooth curve function, then get USL/LSL value by using 6-sigma to calculate quantile spec limits under process capability function. I'd like to know what formula is used to calculate USL/LSL. I'm trying to run the same formula in the excel version.
WebDesignesCrow
Re: How do I get Formula of calculate quantile spec limits in process capability
Hi @Sandra233
Check below link if it can answer your question.
Statistical Details for Capability Indices for Nonnormal Distributions
Find new spec limits by adjusting the CpK value - JMP User Community
The 6Sigma is equivalent to 1.413
