goutam
How do I fix base level for indicator function parameterization
If my data has 1's and 0's in a column for a X and I am running a regression of Y on X,  how can I force JMP to select one of those as baseline values (instead of JMP picking it based on its internal rule) in creating indicator function parameterization? Thanks
Re: How do I fix base level for indicator function parameterization
Add the Value Order column property to X and change the default order.
