VR
VR
How do I do a count formula
I have a data set that had 19 million rows.  Within that data set I want to count the number of instruments a customer has.  I have the customer data in one column and the instruments in another column.  My goal is to select customers that only have 1 instrument.
Thanks
Re: How do I do a count formula
I suggest that you use
     Tables==>Summary
grouping on (Customer, Instruments)
and then on the summary table repeat
     Tables==>Summary
grouping on (Customer)
the table it produces will have the number of instruments,
You can then easily run
     Tables==>Update
to join the counts back into the original table
VR
VR
Thanks so much,  This helps.
