CarlSchmidt
How do I display the heat map for a cell plot?
Using JMP16 and I'm trying to figure out how to display the heat map when I graph a cell plot.
Re: How do I display the heat map for a cell plot?
If you are using Graph Builder to generate the Heat Map, the legend is a default
If you are using the Cell Plot Platform, just click on the red triangle and select Legend
CarlSchmidt
Apology: I meant how do I display the scale bar for the heat map in a cell plot?
CarlSchmidt
Thank you--I figured it was something simple but sometimes I don't see things that are right in front of me.
