The deletion of duplicate rows is starting to frustrate me! I'm on version 18.
In the following script I have Sorted the table on SN (asc), Date & Time (desc). I then create a New Column "DuplicateFlag" and then apply the Formula If( Lag(:SN, 1) == :SN, 1, 0 ). This adds 0 for no duplicate and 1 for duplicate. We then Select the rows = to 1 and Delete the Selected Rows.
This appears to work great when the Date and Time are of different values for the associated SN. However, when the Date & Time are the same for the associated SN it does not delete the duplicate SN.
What suggestions to ensure that all duplicate SN's are successfully deleted.
// Sort the SIDE_1_PRE_MTG table by SN (ascending), Date (descending), and Time (descending)
dt_sort = dt_erroneousdelete << Sort(
By( :SN, :Date, :Time ),
Order( Ascending, Descending, Descending ),
Replace Table
// Add a DuplicateFlag column to mark duplicate SN entries
dt_sort << New Column("DuplicateFlag",
Numeric,
"Continuous",
Formula(
// Select rows where DuplicateFlag is 1 and delete them
dt_sort << Select Where( :DuplicateFlag == 1 );
dt_sort << Delete Rows; // Deletes the selected rows
// Remove the DuplicateFlag column after deleting duplicates
dt_sort << Delete Columns("DuplicateFlag");
