gmc5149
How do I create a new data table combining duplicate rows?
I have a indexed list of production runs of different products (A-H) and their start and end times. Sometimes there are two lines in a row with the same product (rows 1 & 2 and 7 & 8) and I would like those to be combined into one row with the start time of the first row and end time of the second row. How would I use JSL to do this?
Re: How do I create a new data table combining duplicate rows?
I think this should do what you want.
Add new (numeric) column to your table to calculate "groups" with formula like
If(Row() == 1,
	counter = 0;
If(:Product != Lag(:Product),
	counter++;
counter;
Then you can use Summary table to perform the min/max part
Remove and re-order columns from summary table as needed
Here is a script from Enhanced Log to perform those actions
// Open Data Table: Run Time Index.jmp
// → Data Table("Run Time Index")
Open("$DOWNLOADS/Run Time Index.jmp");
// New column: R
Data Table("Run Time Index") << New Column("R",
	Numeric,
	"Continuous",
	Format("Best", 12),
	Formula(
		If(Row() == 1, counter = 0);
			counter
		counter;
// Data table summary
// → Data Table("Run Time Index By (R, Product)")
Data Table("Run Time Index") << Summary(
	Group(:R, :Product),
	Min(:Run Index),
	Min(:Start),
	Max(:End),
	Freq("None"),
	Weight("None"),
	statistics column name format("column"),
	Link to original data table(0)
// Delete columns
Data Table("Run Time Index By (R, Product)") << Delete Columns(:R, :N Rows);
// Move selected column: Run Index
Data Table("Run Time Index By (R, Product)") << Move Selected Columns({:Run Index}, To First);
// Change column modeling type: Run Index
Data Table("Run Time Index By (R, Product)"):Run Index << Set Modeling Type("Ordinal");
If(Row() == 1,
	counter = 0;
	counter++;
counter;
// New column: R
	Numeric,
	"Continuous",
	Format("Best", 12),
	Formula(
			counter
		counter;
	Min(:Run Index),
	Min(:Start),
	Max(:End),
	Freq("None"),
	Weight("None"),
// Delete columns
gmc5149
thank you!
