KevinS
How do I count changes in row values?
I have a large data set where I have blocks of repeating values like this:
A
A
B
A
C
C
C
I would like to count the number of changes in row values or, in other words, a count of rows ignoring consecutive repeated rows.  In this example, the count would be 4 (The third 'A' is a change from 'B', so it counts).  Is there a way to have JMP count rows ignoring repeated and consecutive duplicates?
I'm using JMP 15.2.1.
Re: How do I count changes in row values?
One way would be to create formula using Lag and then you can get max value of that column
If(
	Row() == 1,
		counter = 1;
	, Lag(:col, 1) != :col,
		counter++
counter;
Maybe something like this could also work:
Col Cumulative Sum(Lag(:col) != :col)
Here are a couple of ways to handle this
For Each Row(
	If(
		Row() == 1, count = 1,
		:column 1 != Lag( :column 1 ), count
Show( count );
// Look in the log for the value of count
// or
dt << New Column( "The Count",
	formula(
		If(
			count;
If(
	Row() == 1,
		counter = 1;
		counter++
counter;
KevinS
It seems to be working!  Thanks!
