VD
VD
How do I copy and paste a value based on another column condition
hi,
I want to copy the first row string and paste to all row of the net name column if they have the same group as the group 1 on the sample below
thanks,
group
pin type
Pin
net name
1
U4
31001
1_BUMP_LKG_FH
1
U5
31001
1_BUMP_LKG_FH
1
U3
46997
1_BUMP_LKG_FH
1
U1
46997
1_BUMP_LKG_FH
1
U2
46997
1_BUMP_LKG_FH
2
U2
46840
2_BUMP_LKG_1_FH
2
U2
46999
U2_2_BUMP_LKG_1_LINK1
2
U3
46840
2_BUMP_LKG_1_FH
2
U3
46999
U3_2_BUMP_LKG_1_LINK1
2
U1
46840
2_BUMP_LKG_1_FH
2
U1
46999
U1_2_BUMP_LKG_1_LINK1
3
U2
46886
2_BUMP_LKG_2_FH
3
U2
46732
U2_2_BUMP_LKG_2_LINK1
3
U3
46886
2_BUMP_LKG_2_FH
3
U3
46732
U3_2_BUMP_LKG_2_LINK1
3
U1
46886
2_BUMP_LKG_2_FH
3
U1
46732
U1_2_BUMP_LKG_2_LINK1
4
U2
46884
3_BUMP_LKG_1_FH
4
U2
46998
U2_3_BUMP_LKG_1_LINK1
4
U2
46839
U2_3_BUMP_LKG_1_LINK2
4
U3
46884
3_BUMP_LKG_1_FH
4
U3
46998
U3_3_BUMP_LKG_1_LINK1
4
U3
46839
U3_3_BUMP_LKG_1_LINK2
4
U1
46884
3_BUMP_LKG_1_FH
4
U1
46839
U1_3_BUMP_LKG_1_LINK2
4
U1
46998
U1_3_BUMP_LKG_1_LINK1
Re: How do I copy and paste a value based on another column condition
Is this the table you want?
There are many ways of doing this, one would be to use formula. Here is one example formula:
:"net name"n[Col Min(Row(), :group)]
It uses Col Min to get first row for each group, and then uses that found row to get value from net name column.
VD
VD
Great! It works. Thanks for a quick help.
