How do I combine 2 graphs into 1 PNG?
I have these two graphs that I'm saving as seperatly as PNG, but would like to save both graphs as one image. Is that possible?
I'm using version 18.0.1.
gb1 = Graph Builder(
	Size(879, 689),
	Show Control Panel(0),
	Grid Color("Black"),
	Variables(X(:SiteX), Y(:SiteY), Wrap(:Wafer), Color(:BDO_P1P2)),
	Elements(Heatmap(X, Y, Legend(44), Label("Label by Value"))),
	Local Data Filter(Close Outline(1)),
		Dispatch({}, "SiteX", ScaleBox, {Label Row(Show Major Grid(1))}),
		Dispatch({}, "SiteY", ScaleBox, {Label Row(Show Major Grid(1))}),
		Dispatch({}, "400", ScaleBox,
			{Legend Model(
				44,
				Properties(-1, {Fill Color(32)}, Item ID("01", 1)),
				Properties(-1, {Fill Color(32)}, Item ID("02", 1)),
				Properties(-1, {Fill Color(32)}, Item ID("03", 1)),
				Properties(-1, {Fill Color(32)}, Item ID("04", 1)),
				Properties(-1, {Fill Color(32)}, Item ID("05", 1)),
				Properties(-1, {Fill Color(32)}, Item ID("06", 1)),
				Properties(-1, {Fill Color(32)}, Item ID("07", 1)),
				Properties(-1, {Fill Color(32)}, Item ID("08", 1)),
				Properties(-1, {Fill Color(32)}, Item ID("09", 1)),
				Properties(-1, {Fill Color(32)}, Item ID("10", 1)),
				Properties(-1, {Fill Color(32)}, Item ID("11", 1)),
				Properties(-1, {Fill Color(32)}, Item ID("12", 1)),
				Properties(-1, {Fill Color(32)}, Item ID("13", 1)),
				Properties(-1, {Fill Color(32)}, Item ID("14", 1)),
				Properties(-1, {Fill Color(32)}, Item ID("15", 1)),
				Properties(-1, {Fill Color(32)}, Item ID("16", 1))
		Dispatch({}, "graph title", TextEditBox, {Set Text("Notch up")}),
		Dispatch({}, "X title", TextEditBox, {Set Text("X position")}),
		Dispatch({}, "Y title", TextEditBox, {Set Text("Y position")}),
		Dispatch({}, "Graph Builder", FrameBox,
			{DispatchSeg(RectSeg(1), {Line Width(1), Line Width(1)})}
		Dispatch({}, "Graph Builder", FrameBox(2),
		Dispatch({}, "Graph Builder", FrameBox(3),
		Dispatch({}, "Graph Builder", FrameBox(4),
		Dispatch({}, "Graph Builder", FrameBox(5),
		Dispatch({}, "400", LegendBox, {Set Title("Value")})
	Invisible
filePath = subDir1 || "\BDO_P1P2.png";
gb1 << Save Picture(filePath, "png");
gb2 = Graph Builder(
	Size(858, 639),
	Show Legend(0),
	Variables(X(:Wafer), Y(:BDO_P1P2)),
	Elements(Points(X, Y, Legend(43))),
		Dispatch({}, "Wafer", ScaleBox, {Label Row(Show Major Grid(1))}),
		Dispatch({}, "BDO_P1P2", ScaleBox,
			{Min(10), Max(60), Inc(5), Minor Ticks(0),
			Add Ref Line(39, "Dashed", "Blue", "Spec Upper Limit", 1),
			Add Ref Line(26, "Dashed", "Blue", "Spec Lower Limit", 1),
			Add Ref Line(30.9, "Dashed", "Green", "Spec Target", 1),
		Dispatch({}, "graph title", TextEditBox, {Set Text("")})
	Invisible
filePath = subDir1 || "\BDO_P1P2_Trend.png";
gb2 << Save Picture(filePath, "png");
Re: How do I combine 2 graphs into 1 PNG?
Combine the graphs into same report window (Window / Combine Windows or create a dashboard or script it). Below is simple scripted example
filepath = "$TEMP/myreport.png";
nw = New Window("Two windows",
	V List Box( // Or H List Box
		gb1 = dt << Graph Builder(
			Variables(X(:weight), Y(:height), Overlay(:sex)),
			Elements(Points(X, Y, Legend(9)), Line Of Fit(X, Y, Legend(11)))
		gb2 = dt << Graph Builder(
			Variables(X(:weight), Y(:age), Overlay(:sex)),
nw << Save Picture(filepath, "png");
wait(0);
nw << close window;
Web(filepath); // Open image in default program
 Edit: View menu to Window menu for Combine Windows
wait(0);
nw << close window;
