AN1
AN1
How do I change the Eigenvalue cutoff in Variable Clustering ?
Hello:
I am trying to change the default cutoff for the eigenvalue in variable clustering.  It looks like JMP is using a default value of 1.  Eigenvalue change is not available as an option in the platform.  I looked into the scripting index, and I am not sure how to change the eigenvalue:
dt = Open( "$SAMPLE_DATA/Cities.jmp" );
obj = dt << Cluster Variables( Y( :OZONE, :CO, :SO2, :NO, :PM10 ) );
Any idea of how to change the eigenvalue parameter in variable clustering?
Re: How do I change the Eigenvalue cutoff in Variable Clustering ?
Right now, JMP doesn't offer the feature you mentioned. You could suggest it in the JMP Wish List (menu tab at the top of the window).
