Victor3
How do I assign file folder path when I open file explore?
Hi expert,
I would like to write a jsl to query user to assign a file to import. It's always open the same folder as my jsl file. I would like to open desktop when pop up the file explore. Can I do that?
New Window( "File explore",
	<<modal,
	Spacer Box( size( 20, 10 ) ),
	Text Box( "Choose a log.txt file:" ),
	BB1 = Button Box( "Pick file",
		D = Pick File();
		If( D != "",
			file1 << set text( D )
	file1 = Text Box( ),
Victor Huang
Re: How do I assign file folder path when I open file explore?
Scripting Index has sometimes very good examples
In this case if you want it to open on Desktop, you can use $DESKTOP path variable
New Window("File explore",
	<<modal,
	Spacer Box(size(20, 10)),
	Text Box("Choose a log.txt file:"),
	BB1 = Button Box("Pick file",
		D = Pick File("Select file", "$DESKTOP");
		If(D != "",
			file1 << set text(D)
	file1 = Text Box(),
	<<modal,
		If(D != "",
	file1 = Text Box(),
