How do I add error bars to bivariate fit (y by x)?
Mar 30, 2009 07:00 PM(6500 views)
I am plotting line graphs using analyze>fit y by x. I get a series of points that I then group by treatment and fit each value. I have been unable to get a nice line graph with error bars. I am currently exporting the data back into excel in order to get this graph. Any advice??
If you are fitting a line to a bivariate and want the confidence curves fit, go to the red triangle next to the fit description below the graph. This will give you the option to do either confidence curves fit or confidence shaded fit (same fits, different look).
To generate a line graph with y error bars you can use the Chart-platform under the Graph-menu. Select the line chart from the options in the lower left corner. As X select your treatments, and as Y select your data with the "Mean" option (if you also want individual points in your graph select your Y's twice: as "Data "and as "Mean").
Then in the resulting graph under the red triangle there is the option to add error bars for the mean. You will be prompted to choose from standard error, standard deviation, confidence limits etc.
