lala
Level IX
How can use JSL to loop column names into different variables?
Thanks!
For( i = 1, i <= N Col( dt ), i++,
	ca = Column( i ) << Get Name;
	Eval( Parse( "c" || Char( i ) || "=" || ca || "" ) );//?
a = c1;
b = c2;
Re: How can use JSL to loop column names into different variables?
Usually something like this is a very bad idea and its much better idea to use something like list or associative array, but if you really want to do something like this you are missing quotes if you want to get the names
Delete Symbols();
For(i = 1, i <= N Col(dt), i++,
	ca = Column(i) << Get Name;
	Eval(Parse("c" || Char(i) || "= \!"" || ca || "\!""));//?
Show Symbols();
