I see the issue you are pointing out. It appears that even though the Display Tree indicates there are 4 separate Axes, JMP actually treats them as just 2 axes. Therefore, what has to be done to get as close to what you want as I think I can, one can take the data for Height and Weight into 4 columns, based upon the Sex value, and then plot the 4 variables separately.
Here is the JSL
names default to here(1);
dt = Open( "$SAMPLE_DATA/Big Class.jmp" ) ;
dtSplit = dt << Split(
Split By( :sex ),
Split( :height, :weight ),
Remaining Columns( Drop All ),
Sort by Column Property
gb = dtSplit << Graph Builder(
Variables( Y( :height F ), Y( :weight F ), Y( :height M ), Y( :weight M ) ),
Elements(
Position( 1, 1 ),
Points( Y, Legend( 11 ) ),
Caption Box( Y, Legend( 15 ), Summary Statistic( "Std Dev" ) )
Elements(
Position( 1, 2 ),
Points( Y, Legend( 12 ) ),
Caption Box( Y, Legend( 16 ), Summary Statistic( "Std Dev" ) )
Elements(
Position( 1, 3 ),
Caption Box( Y, Legend( 17 ), Summary Statistic( "Std Dev" ) ),
Points( Y, Legend( 18 ) )
Elements(
Position( 1, 4 ),
Points( Y, Legend( 14 ) ),
Caption Box( Y, Legend( 19 ), Summary Statistic( "Std Err" ) )
Dispatch(
"weight F",
ScaleBox,
{Min( 49.5141101773061 ), Max( 150.319351489306 ), Inc( 20 ),
Minor Ticks( 0 )}
Dispatch(
"400",
ScaleBox,
{Legend Model(
18,
Properties( 0, {Line Color( 21 )}, Item ID( "height M", 1 ) )
), Legend Model(
14,
Properties( 0, {Line Color( 19 )}, Item ID( "weight M", 1 ) )
Dispatch(
"400",
LegendBox,
{Legend Position( {11, [0], 12, [1], 18, [3], 14, [2]} ),
Position( {0, 1, 3, 2} )}
Report( gb )[AxisBox( 2 )] << Add Ref Line(
Col Std Dev( :Height F ),
"Solid",
"Medium Dark Red",
"Std Dev mean",
2
Report( gb )[AxisBox( 3 )] << Add Ref Line(
Col Std Dev( :Weight F),
"Solid",
"Medium Dark Red",
"Std Dev mean",
2
Report( gb )[AxisBox( 4 )] << Add Ref Line(
Col Std Dev( :Height M ),
"Solid",
"Medium Dark Red",
"Std Dev mean",
2
Report( gb )[AxisBox( 5 )] << Add Ref Line(
Col Std Dev( :Weight M ),
"Solid",
"Medium Dark Red",
"Std Dev mean",
2
