Created:
Mar 6, 2020 03:45 PM
| Last Modified: Mar 7, 2020 1:47 PM
(5303 views)
I am trying to create a column called "Flag" where the values are the first Word from column "Test type", i am using "_" as a delimiter for the search. How can i do this in JMP14?
| Test type |
Flag |
| FINAL_PASS_FT2_-40 |
FINAL |
| FIRST_PASS_FT2_-40 |
FIRST |
| FT_COLD |
FT |
| FT_COLD |
FT |
| FINAL_PASS_8745_COLD_QA-40_2_FT |
FINAL |
| FIRST_PASS_8745_COLD_QA-40_2_FT |
FIRST |
| FT_ROOM |
FT |
| FINAL_PASS_8625_ROOM_TEST_2_FT |
FINAL |
| FIRST_PASS_8625_ROOM_TEST_2_FT |
FIRST |
| FINAL_PASS_8315_HOT_AT_105_1_FT |
FINAL |
| FIRST_PASS_8315_HOT_AT_105_1_FT |
FIRST |
Thank you for your help
Karim
