user8421
How can I use a column formula to return the value of a specific row in another column?
Here is an example data table with the 4th column "Desired Formula Column" showing the outcome I am trying to get.
GroupSample NumberData ValueDesired Formula Column
A13535
A2235
A3135
B12222
B2422
B3222
C14040
C2240
C3340
I am looking for a column formula that will enter the data value for sample 1 for each group.
Any help appreciated!
Thierry_S
Re: How can I use a column formula to return the value of a specific row in another column?
Here is a simple formula that I use all the time:
If( Row() == 1,
	:Data Value,
	If( Lag( :Group, 1 ) != :Group,
		:Data Value,
		Lag( :Desired Formula Column, 1 )
Thierry R. Sornasse
Thierry_S
If( Row() == 1,
	:Data Value,
		:Data Value,
Thierry R. Sornasse
ron_horne
Hi @user8421
this is a fun question try adding a column to the table with this formula.
If( :Sample Number == 1,
	:Data Value,
	Lag( :Column 5, 1 )
this is not robust but if you do not change row order you should be fine. otherwise just delete the formula once you have the numbers where you want them.
