How can I see excluded item in graph builder?
I like to only exclude item from the col sum column. As that line is not hide, how can i see that on graph builder chart?
Re: How can I see excluded item in graph builder?
You hold shift + click on red triangle and enable show excluded rows
Excluded rows will then appear lightly transparent
You have to hold Shift while you click on the red triangle, and it should become visible
Setting of the RowState for a given row, sets the entire row to excluded.  If you want to display the X value from the excluded row, I would add a new row that has the X value specified, but with the y column value set to missing.
Jarmo,
I am using JMP18.1.2. Somehow I don't see this option in a graph builder. But I was able to change setting in the preferences.
