natalie_
Level V
How can I find the row and column of a value within a data table?
Hi all,
I need to find the column and row number of a particular value within a data table.   I know how to search for a value within a particular column (ie., row = dt1 << get rows where(:Device == "Device");) , which returns the row number, but what if I don't know what row it will be in?
Is it possible to do this in JMP?  I see how to do it from going to edit then search, but is there a way to do this in JSL?
pmroz
Re: How can I find the row and column of a value within a data table?
If you're looking for text, then this example may be helpful:
dt = open("$sample_data\Bands Data.jmp");
char_cols = dt << get column names(Character, string);
search_string = "E310";
for (i = 1, i <= nitems(char_cols), i++,
    match_rows = dt << get rows where(as column(dt, char_cols[i]) == search_string);
    if (nrows(match_rows) > 0,
        print("Column: [" || char_cols[i] || "] Rows: " || char(match_rows));
pmroz
natalie_
Level V
Thank you, your examples are always great!
I know that the value can only happen once in the file, so I made a while loop instead so that it would not continue to check the other columns for it.
file = Pick File();
dt = Open (file);
for(i=1, i<=ncols(dt), i++,
  column(dt,i) << data type(Character);
  column(dt,i) << set modeling type(continuous);
nCols = dt << Get Column Names ("Character");
found =0;
search_string = "Vtlin";
i=1;
While (found == 0,
  match_rows = dt << get rows where(as column(dt, nCols)==search_string);
  if(nrows(match_rows) > 0, found = 1, i++);
  if(i==nCols, found =1, );
vtlinCol = i;
