rpalese
How can I create a multi-panel graph? JMP Pro 15
Hello community,
I need to put together several graphs from an existing data set similar to the one below. As the annotation says, I need error bars and dots representing individual data points for each. I'd appreciate any and all help in getting this to work and would be happy to Zoom with an expert that can walk me through on screen share.
Rick Palese
Richard S. Palese, PhD
Lecturer, Instrumental Music Education
College of Arts and Sciences School of Music
106D Hughes Hall, 1899 College Road North, Columbus, OH 43210
614.292.2414 Office
palese.2@osu.edu / music.osu.edu
Re: How can I create a multi-panel graph? JMP Pro 15
Please note, the script that I provided, was generated after I had taken your specific sample data and produced a "look-a-like" chart.  The script produced contains axis settings etc. that are based upon the sample data and may not be appropriate for another data table.  My goal for my initial response, was to show you that JMP could produce a chart very closely matching your provided sample.  I developed the chart interactively, and I assumed you would be doing the same for your charts, which will give you the opportunity to set the axes correctly, etc.
I interactively played around with some fake data taken from the Big Class sample data table.  This is the best I could come up with
I have attached the table I used for the development of the graph/chart.  I have embedded the script for the above chart into the data table.  Additionally, the script is also displayed below.
Note:  The maipulation of the data and the Chart Building was all done interactively.    Once it was done, I then extracted the script that generates the graph.
dt = Data Table( "rpalese" );
Graph Builder(
	Size( 525, 458 ),
	Legend Position( "Inside Left" ),
	Variables( X( :age ), X( :sex, Position( 1 ) ), Y( :height ), Color( :sex ) ),
	Elements(
		Bar( X( 1 ), X( 2 ), Y, Legend( 6 ), Label( "Label by Value" ) ),
		Points( X( 1 ), X( 2 ), Y, Legend( 7 ), Jitter( "None" ) )
		Dispatch(
			"age",
			ScaleBox,
			{Label Row(
				1,
				{Label Orientation( "Angled" ), Wrap Lines( 0 ),
				Tick Mark( Label( "." ), Label( "" ) ),
				Tick Mark( Label( "F" ), Label( "" ) ),
				Tick Mark( Label( "Free Practice" ), Label( "" ) ),
				Tick Mark( Label( "Limited N of Trials" ), Label( "" ) ),
				Tick Mark( Label( "M" ), Label( "" ) )}
			), Label Row( 2, Label Orientation( "Angled" ) )}
		Dispatch(
			"height",
			ScaleBox,
			{Min( -1.28454146534123 ), Max( 85.4846123003219 ), Inc( 20 ),
			Minor Ticks( 1 )}
		Dispatch(
			"400",
			ScaleBox,
			{Legend Model(
				6,
				Properties( 0, {Fill Color( 61 )}, Item ID( "Free Practice", 1 ) ),
				Properties(
					1,
					{Fill Color( 28 )},
					Item ID( "Limited N of Trials", 1 )
				Properties( 2, {Transparency( 0 )}, Item ID( ".", 1 ) ),
				Properties( -1, {Fill Color( 61 )}, Item ID( "F", 1 ) ),
				Properties( -1, {Fill Color( 28 )}, Item ID( "M", 1 ) )
			), Legend Model(
				7,
				Properties( 0, {Line Color( 0 )}, Item ID( "Free Practice", 1 ) ),
				Properties(
					1,
					{Line Color( 0 )},
				Properties( 2, {Line Color( 2 )}, Item ID( ".", 1 ) ),
				Properties( -1, {Line Color( 0 )}, Item ID( "F", 1 ) ),
				Properties( -1, {Line Color( 0 )}, Item ID( "M", 1 ) )
		Dispatch(
			"graph title",
			TextEditBox,
			{Set Text( "Free Practice vs. Limited Performance Trials" )}
		Dispatch( {}, "X title", TextEditBox, {Set Text( "" )} ),
		Dispatch( {}, "Y title", TextEditBox, {Set Text( "" )} ),
		Dispatch(
			"Graph Builder",
			FrameBox,
			{DispatchSeg( BarSeg( 1 ), {Set Width Proportion( 1 )} )}
		Dispatch(
			"400",
			LegendBox,
			{Set Title( "" ), Orientation( "Horizontal" ),
			Legend Position( {6, [0, 1, -1], 7, [-1, -1, -1]} )}
rpalese
This is fantastic. Thanks! I'll investigate the set up on this data file and play around a bit with the graph builder script. On an initial glance, I think I understand the approach, but I'm relatively new to JMP and might need some help getting my data file (set up very different from your sample) reformatted to make this work.
Can I reach out with additional questions or Zoom with you for additional guidance?
614.292.2414 Office
More questions are always welcomed.  Zoom might be an option.  Spending more time reading the documentation would be a better choice.
rpalese
Gotcha. I've played around with your script and reformatted my data to fit your template. This all worked fairly well for one set of graphs:
But didn't for another. Notice the space between the bars has shifted:
I've searched for a solution and investigated the script, but can't figure out how to manipulate this. Would you be able to help? Again, if a quick Zoom is easiest, I'm happy to coordinate a time. Thanks again for all your help!
614.292.2414 Office
