fkp
fkp
How can I create a column switcher in a final merged data table from a list variable created in one of the source tables?
I have two data sources that being updated on a regular basis, resulting in new columns.  These are are merged via JSL scripting which works well but, I'd like to embed a graph with a column switcher that grows as more columns are added.
For example, say HPLC data comes from Instrument A and Instrument B.  Each column is a separate sample, with more samples being added over time.  I'd like to create a simple XY chart in the final data table for my 'A' samples, so that as more columns are added, the column switcher grows as well.  (Similar with B and even C, if a third instrument is added later).
I've created a variable from the A table before I merge the data with B, but how can I pass the list (or evaluate it ) so that the final table recognizes the variable or has explicit column names?
A_columns = dt_A <<Get Column Names();
//Merge A and B based on time column
Final_Table =dt_B << Update(
With(dt_A)),
Match Columns( :Time = :Time)
Final_Table <<New Script("Graph",
Graph Builder(
Size( 546, 565 ),
Show Control Panel( 0 ),
Variables( X( :Time ), Y( A_columns[1] ) ),
Elements( Points( X, Y, Legend( 3 ) ), Smoother( X, Y, Legend( 4 ) ) ),
Column Switcher( A_columns[1], A_columns)
 This seems to work well when I obtain a list of columns from the final table, but trying to use a variable created from another table is causing issues.
Re: How can I create a column switcher in a final merged data table from a list variable created in one of the source tables?
In that case I consider building the column list dynamically within the table script
table_script_expr = Expr(
	cols = Current Data Table() << Get Column Names();
	Remove From(cols, 1); // drop first column
	gb = Graph Builder(
		Size(528, 448),
		Show Control Panel(0),
		Variables(X(:lot_id), Y(Eval(cols[1]))),
		Elements(Points(X, Y, Legend(3)))
	gb << Column Switcher(
		cols[1],
		Remove(cols, 1)
Eval(EvalExpr(
	dt << New Script("Graph",
		Expr(NameExpr(table_script_expr))
You can avoid evaluation if you just create the graph and save that as script (I use this "trick" quite often)
cols = dt << Get Column Names();
gb = dt << Graph Builder(
	Size(528, 448),
	Elements(Points(X, Y, Legend(3))),
	Column Switcher(
		cols[1],
		Remove(cols, 1)
	Invisible
gb << Save Script to Data Table("Graph"); // this will remove the need for evaluation
wait(0);
gb << close window;
and if you wish to evaluate
// If you wish to evaluate, this should work even though the script will look a bit weird due to lack of ":" in columns
// If it doesn't you for some reason, you will have to build the list in a bit different manner for evaluation
Eval(EvalExpr(
	dt << New Script("Graph2",
		Graph Builder(
			Size(528, 448),
			Variables(X(:lot_id), Y(Expr(cols[1]))),
			Column Switcher(
				Expr(cols[1]),
				Expr(Remove(cols, 1))
Do you always wish to use all expect for the first column (:Time) in the column switcher?
fkp
fkp
In this case yes - always the first column which will always have the same name.
	gb = Graph Builder(
		Size(528, 448),
		cols[1],
		Remove(cols, 1)
Eval(EvalExpr(
	Size(528, 448),
	Column Switcher(
		cols[1],
		Remove(cols, 1)
	Invisible
wait(0);
gb << close window;
Eval(EvalExpr(
		Graph Builder(
			Size(528, 448),
			Column Switcher(
				Expr(cols[1]),
fkp
fkp
Thank you!
