hacketkm
How can I combine 2 columns into one?
I would like to combine two columns into one. My data looks like the table below where "." represents missing data. I would like to make a column which resembles Column C.
Column AColumn B
.2013
.2014
2016.
2017.
Column C
2013
2014
2016
2017
reeza
Re: How can I combine 2 columns into one?
I'm not familiar with JMP but isn't the first condition checking if the cell in A is blank versus missing?
SAS has a keyword, missing, does JMP have the same?
ie
If(is missing(:Column A) , :Column A, :Column B)
hacketkm
So far I have tried adding a new column with the formula: If( :Column A != "", :Column A, :Column B) but this doesn't work and I'm not sure why. It fills in the values from Column A but not from Column B.
reeza
ie
hacketkm
Thank you, I was able to get the formula to work using Is Missing().
