xxvvcczz
How can I append the Schedule GUI into my app? I tried appending it into an Hlistbox but it didn't like.
Is it possible to get the schedule gui appended in an hlist box like any other GUI window?
Re: Function that works when clicked from a button and when run as a script doesn't work when fired from the "Schedule"
I suspect the issue is a scoping issue.  You may want to try setting up a new namespace and always assign dtf to the name space.  That may eliminate the error you are getting.
xxvvcczz
it definitely was a scoping issue.
