KurtAnderson
How can I Fit y by x, with 2 By groups, to display in rows with By as columns?
I have one x and multiple y.  I have only 2 By groups, although I could have more and I think this question would be valid.  I would like to display the y by x in columns with the By groups as columns.
After creating the plots using Fit y by x, if I choose "Arrange in rows" = 2, the default display will place all By group 1 first, then By group 2, etc.  I'd like to visually observe how y1 responds to x within By group 1 side-by-side with By group 2.  To plot both By groups on the same y by x, or using Graph Builder, is too messy.
Can I teach the "Arrange in rows" feature to place the By groups in parallel columns?  I looked in Preferences and couldn't find a way to do it.  Thanks.
Re: How can I Fit y by x, with 2 By groups, to display in rows with By as columns?
I checked the Scripting Index, and Fit Group does not appear to support the LineUp Box().  I believe you will get what you want, if you just replace
Fit Group(
with
nw = New Window( "Output",
the results will be displayed in your 2 columns
	Lineup Box( N Col( 2 ),
		Bivariate(
			Y( :weight ),
			X( :age ),
			By( :sex ),
			Fit Line( {Line Color( {212, 73, 88} )} )
		Bivariate(
			Y( :height ),
			X( :age ),
			By( :sex ),
BTW, if you click on the JSL at the top of the Discussion Entry, and then cut and paste your JSL into the JSL Entry Window, the code is displayed in a more readable form for the Community Members
Here is a simple method to align the output.  It does assume that there are data at each x and y combination
		bivariate(
			y( :height ),
			x( :weight ),
			by( :age,:sex  )
KurtAnderson
Thanks Jim.  I'm less than a novice coder.  My code results in a blank page.  X and Y are continuous; By (material) is categorical.  All variable names are sanitized.  Thanks in advance for your help.
Fit Group(
		Bivariate(
			Y( :"delP/delQ"n ),
			X( :M wt% ),
			By( :material ),
		Bivariate(
			Y( :" flow rate at 5 deg"n ),
			X( :M wt% ),
			By( :material ),
		Bivariate(
			Y( :" flow rate at 30 deg"n ),
			X( :M wt% ),
			By( :material ),
		Bivariate(
			Y( :" calc outlet (inches)"n ),
			X( :M wt% ),
			By( :material ),
		Bivariate(
			Y( :" wall angle (deg)"n ),
			X( :M wt% ),
			By( :material ),
		Bivariate(
			Y( :" rathole (inches)"n ),
			X( :M wt% ),
			By( :material ),
		Bivariate(
			Y( :"off gas"n ),
			X( :M wt% ),
			By( :material ),
Fit Group(
with
		Bivariate(
			Y( :weight ),
			X( :age ),
			By( :sex ),
		Bivariate(
			Y( :height ),
			X( :age ),
			By( :sex ),
