miguello
How alter shapes/text added through Add Graphic Script?
Let's say I want to add custom text or a shape on my graph using "Add Graphics Script":
New Window( "Example",
	gb = Graph Builder(
		Size( 528, 456 ),
		Show Control Panel( 0 ),
		Variables( X( :weight ), Y( :height ), Overlay( :sex ) ),
		Elements( Points( X, Y, Legend( 9 ) ), Smoother( X, Y, Legend( 10 ) ) ),
rgb = gb << Report;
framebox = rgb << XPATH( "//FrameBox" );
framebox << Add Graphics Script(
	"Front",
	Description( "CustomText" ),
		Text( "left", 0.05, {100, 55}, "This is my custom text" ) ;
		Line( {80, 50}, {160, 65} )
How do I later change, let's say, font or font size? How do I change line color or style? How do I get references to them to do things like hide, show, delete, etc.?
Re: How alter shapes/text added through Add Graphic Script?
Scripting index has answer to all of these (Text Size, Text Font, Text Color)
New Window("Example",
	Graph Box(
		Text Size(100);
		Text Color("Blue");
		Text Font("", "italic");
		Text({50, 20}, "label");
Pen Color(), Line Style()
New Window("Line Style Example",
	Graph Box(
		Frame Size(500, 400),
		Line Style("Dotted");
		Pen Color("Blue");
		Pen Size(2);
		Line([10 30 90], [88 22 44]);
Scripting Guide > Scripting Graphs > Add Lines, Arrows, Points, Shapes, and Text
Edit: added link to Scripting Guide
Here is an example taken directly from the Scripting Index for the
     Delete Graphics Script
message
Open( "$SAMPLE_DATA/Big Class.jmp" );
biv = Bivariate( Y( :weight ), X( :height ), FitLine );
rbiv = biv << report;
framebox = rbiv[frame box( 1 )];
	Transparency( 0.5 );
	Fill Color( {1.0, 0.5, 0.0} );
	Polygon( [60, 72, 57], [75, 120, 120] );
	Fill Color( {0.0, 0.5, 1.0} );
	Polygon( [60, 72, 57], [150, 120, 120] );
Wait( 2 );
framebox << Remove Graphics Script( 2 );
miguello
Ok, that covers some of it.
What if I want that text to be smaller in the first place? Or blue? Or italics? How do I achieve that?
And what if I want line to be dotted and also blue?
	Graph Box(
		Text Size(100);
		Text Color("Blue");
	Graph Box(
		Pen Color("Blue");
		Pen Size(2);
miguello
I figured the rest. They come as separate commands in Graphics Script. Not as properties of or messages to "Text" or "Line".
Hi @txnelson ,
That's a great example, but I think you meant to write "Remove Graphics Script" instead of "Delete Graphics Script".
By the way, the Scripting Index is online now. https://jsl.jmp.com
You can link directly to functions and messages:
https://jsl.jmp.com/All%20Categories/Display%20Boxes/FrameBox.html#remove-graphics-script
You won't be able to run directly from the web page like you can from the Scripting Index in JMP, but there's a convenient copy button for each script in the top right corner.  The online Scripting Index can help JMP Live user's edit their scripts on a device that doesn't have JMP installed.
I hope you find this useful.
~John
