kuanaunwei
How To remove rows on specific columns
The above table is just an example of my data set. I have 100k rows and 500+ columns. My question is how to remove the "aaa" rows
Re: How To remove rows on specific columns
I am not sure what you want the final result to be.  If you want the resulting table to be:
dt = Current Data Table();
// Get all of the column names
colNameList = dt << get column names( string );
// Remove the first column name from the list
Remove From( colNameList, 1, 1 );
dt << Begin Data Update;
// Loop across all columns in the list and recode them
For( i = 1, i <= N Items( colNameList ), i++,
	dt << Recode Column(
		As Column( dt, colNameList[i] ),
		{Map Value( _rcOrig, {"aaa", " "}, Unmatched( _rcNow ) )},
		Update Properties( 1 ),
		Target Column( As Column( dt, colNameList[i] ) )
dt << End Data Update;
If the final result is
// Loop across all columns in the list and find rows
// that have aaa for that column
	dt << select where(
		As Column( dt, colNameList[i] ) == "aaa",
		current selection( "extend" )
// Delete all selected rows
dt << delete rows;
For future discussions where you provide an image of a data table, please insert it as a table and not as a picture of the table, or if possible attach the table.  This will remove the requirement of the responder to have to spend the time required to individually create the table(s).
	dt << select where(
dt << delete rows;
