Sean_ShCn0
How I can change the data type from "continous" to "characters" from all the columns in current data table in one JSL sentence ?
For each column(
	col,
	dt,
	If( col << Get Modeling Type == "continous" & Contains( col << Get Name, "Layer Count" ),
		col << Set Data Type( Character )
I tried to ask AI, then i get some proposals, above is one sample, but it is not work. my version is JMP 18
Re: How I can change the data type from "continous" to "characters" from all the columns in current data table in one JSL sentence ?
AI is quite bad with JSL, Scripting Index or using JMP to create example script is much better.
Here is basic example
For Each({colname}, Current Data Table() << Get Column Names("Continuous", "String"),
	Column(Current Data Table(), colname) << Set Data Type("Character");
JMP created script
// Standardize column attributes
Local({old dt = Current Data Table()},
	Current Data Table(Data Table("Big Class"));
	For Each({col, index}, {:name, :age, :sex, :height, :weight},
		col << Set Data Type(Character(7)) << Set Modeling Type("Nominal") <<
		Compact()
	Current Data Table(old dt);
Sean_ShCn0
It works, I learn a new skill, thanks.
KR
Sean
