shiguelita
How Can I use script to create a new table with Concatenate?
Hey guys,
I'm beginner in JMP's scritp and I want to know how I can use script to create a new table using Concatenate.
My script is:
dt =  Open( "C:\EKS\ETAMS\concat1.jmp");
dt << Set Name ("conc1");
dt =  Open( "C:\EKS\ETAMS\concat2.jmp");
dt << Set Name ("conc2");
dt << Concatenate("conc1", Output Table( "Combined" ));
But it's just opening the Concatenate window, it doesn't create a new table. What Am I doing wrong?
Please, help me! =(
Regards
Talita Shiguemoto
ms
Super User (Alumni) ms
Re: How Can I use script to create a new table with Concatenate?
You're almost there! Assign the two tables to two different variables. There is no need to rename the tables.
dt1 = Open("C:\EKS\ETAMS\concat1.jmp");
dt2 = Open("C:\EKS\ETAMS\concat2.jmp");
dt2 << Concatenate(dt1, Output Table("Combined"));
ms
shiguelita
Hey MS, thank you very much. It worked! *_*
