Created:
Jul 20, 2021 09:54 AM
| Last Modified: Jun 11, 2023 4:49 AM(4256 views)
I would like to add a hover over text to a column name. In other words, I would like to see a note to a column when I hover over on its column name without going to the column properties notes. Is it possible?
Great Idea. Are you thinking that when viewing a data table, that when you hovered over a column that had Note column property set for it, the Note would be displayed? Or are you looking for the Note to be displayed elsewhere too?
