lwx228
Level VIII
Hopefully JMP16 will refine these recommendations.
I am glad to see that JMP15 has been produced.
To make the JMP victory smoother, here are some tips:
1. When JMP changes the new language in stock selection, it will revert to the original language. All the previously set Settings have disappeared, only the default Settings have been restored.
lwx228
Level VIII
Re: Hopefully JMP16 will refine these recommendations.
2. It would be more perfect if JMP recorded the operation of each step as JSL, and the code obtained by excel recording macro is more detailed.
Good idea. This entry needs to be added to the JMP Wish List so that it officially gets added to the items the JMP folks will review.
lwx228
Level VIII
3. hope that JSL can add the ability to read and change binary files directly.I often do this with VBA.
lwx228
Level VIII
I hope JMP is not just a statistical tool, but a more powerful quantitative tool and data mining tool.
I don't know if I put it right.Thank you very much!
