wongpl
Histogram count
I have plotted a histogram and plan to extract the histogram count in each column for further data manipulation.
can i know how i can get the row count ( orange arrow) in the histogram column and extract it in a table or variable/array?
ms
Super User (Alumni) ms
Re: Histogram count
One way is to choose Save/Level Numbers found in the red triangle menu in the distribution report. A column with level ID's is then added to the original data table. Use e.g. Summary in the Tables menu to get the counts by selecting the ID column Level N in the Group filed and N of your variable of interest in the Statistics field.
ms
Re: Histogram count
tjmills
Re: Histogram count
You can also use the Save/Midpoint to save the data value of the histogram rather than just the bin number.
theseventhhill
Re: Histogram count
If I have more than 100 such distributions, how do i do a save levels options as a save all ? I hope there is a efficient way to export for each distribution
Re: Histogram count
Holding down the CNTL key, while selecting the Save==>Level Numbers will generate the Level Numbers for all distributions that are displayed.
The holding down of the CNTL key while selecting options, or changing the size of a graph, etc. is a universal JMP option. The feature is documented in the Using JMP book
     Help==>Books==>Using JMP
or in the 14th "Tip of the Day"
     Help==>Tip of the Day
