john_madden
Hiding rows in data table view
When a Cols > Hide is chosen, the column collpases and is no longer visible in the table view.
When Rows > Hide is chosen, the row gets a row state icon of [mask], but the row is still visible in table view.
I know that hiding rows is more about hiding their data in *plots*, but still…is there a way to not show hidden rows in the table view?
Re: Hiding rows in data table view
Your description of how hiddent columns and rows are handled is correct.  There is not an option that makes hidden rows invisible within the data table.
The only way to display what you are referring to, would be to create a new subsetted data table, with the rows you want hidden actually deleted.
