DanAlexander
Hiding graph in Bivariate analysis?
I have a script which include a Bivariate analysis, however I would like to have just the Linear Fit statistics table show  up, and hide the graph itself.
this_dt << Bivariate(
		Y( Column(this_dt, this_cols[j])),
		X( :"Time (Months)" ),
		By( :"Lot Number" ),
		Fit Line,
		Invisible
As you can see I included the Invisible condition in Bivariate( ), but the graph is still showing up in my JRN file, and I am not sure how to get rid of it.
DanAlexander
Re: Hiding graph in Bivariate analysis?
Thank you for your suggestion.
I also found an alternative solution which I can write within Bivariate().
SendToReport( Dispatch( {}, "", ListBox, {Visibility( "Collapse" )} ) )
The above line hides the box containing the Bivariate plot.
biv = this_dt << Bivariate(
		Fit Line,
		Invisible
biv rep = biv << Report;
// one way
biv rep[PictureBox(1)] << Delete;
// other way
biv rep[PictureBox(1)] << Visibility( "Collapse" );
DanAlexander
KarenC
I see you have ways to hide it but I would ask why? The plot is my favorite part of bivariate (unless you have multitudes of them in which case I would use response screening). Happy World Stats Day!
DanAlexander
I am using the Bivariate function just to generate Linear fit statistics for my main graph. I am using V List box and H List box to generate a plot using graph builder, and then Bivariate to generate the linear fit statistics for each lot number in an H List box beside the plot. Each graph builder plot may have up to 20-30 Bivariates associated with it.
If you can suggest a better alternative, I would love to hear it! Below is an example of my script, sorry if it is confusing, I had to hide specific file paths and columns names.
		// Generating Graphs
setup = Function({dt}, {Default Local},
	dt = Open ( "file.JMP" );
	dt << Select Where(:"column example" == "string example" );
	cfg1 = EvalList({dt << Data View, { "col1", "col2", "col3", "coln"}});
	EvalList({cfg1});
build_graphs = Function({cfgs}, {Default Local},
	win = New Window( "window", vlb = V List Box() );
	ncfg = NItems(cfgs);
	for(i = 1, i <= ncfg, i++,
		{this_dt, this_cols} = cfgs[i];
		ncols = NItems(this_cols);
		for(j = 1, j <= ncols, j++,
			vlb << Append(H List Box (
					this_dt << Graph Builder(
						Show Control Panel( 0 ),
						Size( 600, 400),
						Variables(
							X( :"X axis" ),
							Y( Column(this_dt, this_cols[j]) ),
							Overlay( :"overlay" )
						Elements(
							Points( X, Y, Legend(12) )
							Dispatch(
								ScaleBox,
								{Format( "Fixed Dec", 10, 0 ), Min(0), Max(50), Inc(6),
								Minor Ticks(0)}
							X( :"X axis" ),
							By( :"overlay" ),
							Fit Line,
		win
cfgs = setup(dt);
Show(cfgs);
win = build_graphs(cfgs);
Show(win);
win << Save Journal("file.jrn", embed data(1));
