Kenobi
Hide and exclude in multiple select where
I have an add-in that performs hide and exclude in a for loop. One thing I observed was that the previous hide and exclude gets overwritten by the next column condition. Additionally, I realized that it also overwrote my manual hide and exclude. I have two questions:
1. Is there a way to concatenate multiple select where and then perform an overall hide and exclude?
For( i = 1, i <= N Items( list_of_cols ), i++,
            dt << select where( As Column( dt, list_of_cols [i] ) != "");
            dt << hide and exclude;
2. Is there a way to keep the hide and exclude in place (manually performed in first two lines), and hide extra rows later on in the script?
dt << select where( :Comment =="Exclude");
For( i = 1, i <= N Items( list_of_cols), i++,
        dt << select where( As Column( dt, list_of_cols[i] ) != "");
Thank you!
Re: Hide and exclude in multiple select where
The Select Where() function has the ability to "Extend" or "Restrict" the previous Select Where.  See the Scripting Index for details.  Here is an example that shows how to do that for your application.
dt << Select Where( :Age == 14 );
Wait( 0 );
dt << Select Where( :sex == "M", current selection( "extend" ) );
Additionally, you could add to your Hide and Exclude, an additional option that only forces the selection to Turn On the Hide and Exclude
dt << Hide and Exclude(1);
            dt << hide and exclude(1);
ErraticAttack
Good to know!
Jordan
