Help with an if statement
mrosenthal
I am probably missing something basic here. I am trying to change a column's values by using a combination of two other column values. I type in the following if statement and the column values do not change. What am I missing here? Thanks for any tips and advice.
dt = Data Table( "20210811Miflezet_CAPCMP.jmp" );
dt << Begin Data Update;
If( :justice_decision_REC_RILE2 == "reject" & :RILE_Calc2a == "center"
	 :Rile_Calc3 == "center"
	:justice_decision_REC_RILE2 == "accept" & :RILE_Calc2a == "center"
	:justice_decision_REC_RILE2 == "reject" & :RILE_Calc2a == "left"
	 :Rile_Calc3 == "right"
	:justice_decision_REC_RILE2 == "accept" & :RILE_Calc2a == "left"
	:Rile_Calc3 == "left"
	:justice_decision_REC_RILE2 == "reject" & :RILE_Calc2a == "right"
	:justice_decision_REC_RILE2 == "accept" & :RILE_Calc2a == "right"
dt << End Data Update;
Re: Help with an if statement
In your original JSL you probably ( edit: also ) want to change
Rile_Calc3 == "center" // compare. the result of the compare (0 or 1) will be the result of the if(), see below
to
Rile_Calc3 = "center" // assign value
JSL if statements return a value; you could write it as
:Rile_Calc3 = If(
   :justice_decision_REC_RILE2 == "reject" & :RILE_Calc2a == "center",  "center",
   :justice_decision_REC_RILE2 == "accept" & :RILE_Calc2a == "center",  "center",
   :justice_decision_REC_RILE2 == "reject" & :RILE_Calc2a == "left",  "right",
   :justice_decision_REC_RILE2 == "accept" & :RILE_Calc2a == "left", "left",
   :justice_decision_REC_RILE2 == "reject" & :RILE_Calc2a == "right", "left",
   :justice_decision_REC_RILE2 == "accept" & :RILE_Calc2a == "right", "right",
   :Rile_Calc3 // or "Unknown" ? depends how you want to handle the unexpected case.
If you know there are no unexpected cases, you can omit the final otherwise clause. But the nature of unexpected cases is to show up when least expected.
If Secrets
You could use either For Each Row or Set Each Value. Below is an example:
For Each Row(
	If(:sex == "F",
		:age = .
dt:weight << Set Each Value(
	If(:sex == "M",
		:height
mrosenthal
Thanks for the answer! As the various scripting guides show, it should be the right thing yet it did not work here. I assume something was wrong with the data table and all the processing I already did on these variables. Eventually, the workaround was to concatenate the two nominal columns to one and then recode the expressions I got there to the desired outcomes. Thanks again.
to
:Rile_Calc3 = If(
If Secrets
mrosenthal
That actually worked. I did one small tweak using @jthi 's post and did small changes in @Craige_Hales's code. The final format that worked for me was this:
dt = Data Table( "20210812Miflezet_CAPCMP.jmp" );
For Each Row(
 If(
  :just_dec_rec == "reject" & :RILE_Rec == "center",  :RILE4="center",
   :just_dec_rec == "accept" & :RILE_Rec == "center", :RILE4= "center",
   :just_dec_rec == "reject" & :RILE_Rec == "left", :RILE4= "right",
   :just_dec_rec == "accept" & :RILE_Rec == "left", :RILE4="left",
   :just_dec_rec == "reject" & :RILE_Rec == "right", :RILE4="left",
   :just_dec_rec == "accept" & :RILE_Rec == "right", :RILE4="right"
