hacketkm
Help with an IF() statement?
I would like to use an IF() statement to assign a value to a column if another column meets a certain requirement.
Column 1Column 2
A1
B2
UNKNOWN
C3
D = 100;
IF( :Column 1 == "UNKNOWN", :Column 2 = D);
The script isn't recognizing D as the value "100". Could anyone help me out?
Re: Help with an IF() statement?
You just need to address it by row.
D =100;
for each Row(
      if(:"Column 1"[]=="UNKNOWN",:"Column 2"[] = D
The other option is to create a new column with a formula.  Then your solution would work.
D =100;
for each Row(
