MathStatChem
Help with Run Program
I want to run PanDoc on a markdown file using JMP's Run Program command.  I am on MacOS.  I have looked at the scripting guide and the Scripting Index, but I cannot seem to get the correct syntax.
On my system PanDoc is installed at
/opt/homebrew/Cellar/pandoc/3.7.0.2/bin/pandoc
the command line to use pandoc would be this
pandoc <path>/markdown.md -f markdown -o <path>/markdown.html
I tried this and will not work.  Note that <path> is the path to the files, I did not include that here.
Run Program(
   Executable("/opt/homebrew/Cellar/pandoc/3.7.0.2/bin/pandoc"),
   Options(
"<path>/markdown.md -f markdown -o <path>/markdown.html"
Any idea on how I can get this to work?
MathStatChem
Re: Help with Run Program
Nevermind, I figured it out.  You have to separate the options string in to pieces... this works
Run Program(
   Options({"<path>/markdown.md", "-f", "markdown", "-o",  "<path>/markdown.html"})
MathStatChem
Run Program(
Mac does require the parameters split. Win works either way.
MathStatChem
That is good to know.  Thanks.
