Edit 2:
I finally made the script to work, following the recommendation from Jarmo and this post:
JSL Help with: Get As Report & Table Box
Now when I click on a row in the report, it run the script based on the selected row, which is exactly what I needed
![image.png image.png](/t5/image/serverpage/image-id/69377i5B72F87F6AC3E4CE/image-size/medium?v=v2&px=400)
Script below, it needs the 2 tables open that I joined in my first message
Thanks
- voiz
dt7 = Data Table("Summary");
dt = Data Table("datatable_test");
dt7 << clear select;
dt7 << Clear Column Selection();
RptWin = New Window( "Data Table as report",
Outline Box("Data Table as Report",
dt7_Rpt = dt7 << Get as Report();
tb = dt7_Rpt[Table Box( 1 )];
tb << Set Heading Column Borders( 1 );
tb << Set Selectable Rows( 1 );
tb << Set Row Change Function(
Function( {this},
{SelRows},
SelRows = this << Get Selected Rows;
If(
N Items( SelRows ) > 1, Throw( "Too many items selected!\!rOnly one selection possible." ),
N Items( SelRows ) == 1,
dt7 << Clear Select;
rn = dt7 << Select rows( SelRows ) << get selected rows;
show (rn[1], dt7:Metric[rn]);
Factors = dt7 << get column names( "string" );
Eval(
Eval Expr(
For( i = N Items( Factors ), i >= 1, i--,
CurrCol = Column( dt7, Factors[i] );
If(Char( CurrCol[ rn[1] ] ) == "Ok" | Factors[i] == "Metric"| Factors[i] == "Graph",
Remove From( Factors, i, 1 )
show (Factors);
Try(FactorA = "X( :" || Char( Factors[1] ) || ", Position( 1 ))");
FactorB = "X(1)";
For( j = 2, j <= N Items( Factors ), j++,
Try(FactorA = Char( FactorA ) || ",X( :" || Char( Factors[j] ) || ", Position( 1 ))");
FactorB = Char( FactorB ) || ",X( " || Char( j ) || " ) ";
Show( dt7:Metric[rn], FactorA, FactorB );
Key = dt7:Metric[rn];
If (Factors != {},
Eval(Parse(Eval Insert(
" dt << Graph Builder(
Size( 534, 464 ),
Show Legend( 0 ),
Variables(Y( ^Key^ ), ^FactorA^),
Elements(
Box Plot( Y, Legend( 18 ), ^FactorB^ ),
Caption Box(X, Y, Legend(20), Summary Statistic( \!"N\!" ),Location( \!"Graph per factor\!" ))),
Dispatch(
ScaleBox,
{Min( -0.485125992718803 ), Max( 5.53364268893602 ), Inc( 1 ),
Minor Ticks( 0 )}
Size( 534, 464 ),
Show Legend( 0 ),
Variables(Y( ^Key^ )),
Elements(
Box Plot( Y, Legend( 18 )),
Caption Box(Y, Legend(20), Summary Statistic( \!"N\!" ))),
Dispatch(
ScaleBox,
{Min( -7.06199976676385 ), Max( 26.8097086791615 ), Inc( 5 ),
Minor Ticks( 0 )}
