Hi there!
I'm trying to plot a contour graph in JMP similar to the example below, plotted via minitab:
To make the response surface below on JMP, I saved the formula for the predicted response H in a column and plotted the following surface:
I would like to plot the projection of this response surface similar to the minitab example given, but I can only get the curves in the JMP surface predictor (which doesn't interest me, in this case: I want to plot it similar to the minitab example):
Plotting the contour via JMP's contour profile using the H saved prediction formula, I only get this not-at-all-satisfactory surface:
Any ideas on how to plot this contour similar to the one in mintab? with the curves not being polygonal and broken, with gradient filling and color legend?
Thanks for the time!
