Thank you for your response Jim!
Unfortunately, I don't have a single spec limit for my column as there's a distinction between the values based on another column so I haven't found a way to do traditional column spec limits yet without completely splitting my data into two tables.
I was ultimately able to find the solution to my problem by using Get Rows Where:
G1 = dt << Get Rows Where (:Column 1 == "Group1");
G1_Min = Eval( Min((LSL[1]*0.95), Min(:Column 2[G1])));
G1_Max = Eval( Max((USL[1]*1.05), Max(:Column 2[G1])));
dt << clear select;
G2 = dt << Get Rows Where (:Column 1 == "Group2");
G2_Min = Eval( Min((LSL[2]*0.95), Min(:Column 2[G2])));
G2_Max = Eval( Max((USL[2]*1.05), Max(:Column 2[G2])));
dt << clear select;
Then to graph within dispatch section (for the first graph, second is duplicate with 1->2):
Dispatch ({Min(G1_Min), Max(G1_Max), Inc( Eval((G1_Max - G1_Min) / 7))),
Add Ref Line( LSL[1], "Solid", "Medium Dark Blue", "LSL", 1 ),
Add Ref Line( USL[1], "Solid", "Medium Dark Blue", "USL", 1 )}
* Note I forgot to mention in my original question that the USL/LSL are already defined in a lists and used for the reference lines.
