Help! Conditional Statements containing Missing Values
I am trying to create a column that labels a pair of points
as falling into category “I”, “II”, “III”, or “IV”.  The pair of points is
based off of two columns, and some cells have missing values.  I am
certain my code is logically correct. Can anyone help me find a working solution?
Below are several of my JSL attempts:
For Each Row(Assign(:Quadrant_Running = If(Is
Missing(:Running_Y), Continue(), Is Missing(:Running_X), Continue(), If(:Running_Y
>= 3 & :Running_X >= 3, "I", If(:Running_Y > 3 &
:Running_X < 3, "II", If(:Running_Y < 3 & :Running_X <
3, "III", "IV"))))))
Missing(:Running_Y), Continue(), Is Missing(:Running_X), Continue(), :Running_Y
>= 3 & :Running_X >= 3, "I", :Running_Y > 3 &
:Running_X < 3, "II", :Running_Y < 3 & :Running_X <
3, "III", "IV"))
I have also attempted using a conditional “Or” :  If(Is
Missing(:Running_Y)|Is Missing(:Running_X), Continue())
And also:  If(Is Missing(:Running_Y|:Running_X),
Continue()).
Thanks for any assistance!!!
Re: Help! Conditional Statements containing Missing Values
Actually, I think the Continue() from your original script is OK -- you just need to remove the Assign().
Also, your second attempt (without the Assign()) is more compact:
For Each Row(
        Is Missing( :Running_Y ), Continue(),
        Is Missing( :Running_X ), Continue(),
        :Running_Y >= 3 & :Running_X >= 3, "I",
        :Running_Y > 3 & :Running_X < 3, "II",
        :Running_Y < 3 & :Running_X < 3, "III",
        "IV"
Michael Crotty
Sr Statistical Writer
JMP Development
Does this script do what you're looking for?  I just removed the Assign() function and changed the Continue()'s to empty strings (""), so that Quadrant_Running will be a missing string when one or both of your X/Y columns is missing.
For Each Row(
        Is Missing( :Running_Y ), "",
        Is Missing( :Running_X ), "",
        If( :Running_Y >= 3 & :Running_X >= 3,
            "I",
            If( :Running_Y > 3 & :Running_X < 3,
                "II",
                If( :Running_Y < 3 & :Running_X < 3,
                    "III",
                    "IV"
Michael Crotty
JMP Development
For Each Row(
        "IV"
Michael Crotty
JMP Development
Thanks for your help guys!
The assign statement was more compact, and I ended up able to use the Continue() statement.
The issue was the settings on my column, I had not changed them to character values when I originally created the column. Doing so allowed the formula to run!
