  • Due to inclement weather, JMP support response times may be slower than usual during the week of January 26.
    To submit a request for support, please send email to support@jmp.com.
    We appreciate your patience at this time.
Level XIII
Heatmap - with borders
In some session with @julian I leaned how to make Heatmap Plots more attractive by adding some borders around the cells.
Other options - like the pattern -  can be controlled via the Control Panel on the left.
This one unfortunately not - it has to be applied via right Click into the graph/Customize... - and separately for each subplot.
On one hand, this is nice because every subplot can be configures individually - on the other hand: this can take some time.
If there are several open subplots, how can I change all subplots at once - and how can I change the setting, such that (when the data table is updated and new subplots appear the) new subplots start with linewidth=1?
Most of such right Click commands can be broadcasted to all subplots by pressing CTRL.
But for Customize ... this doesn't seem to be possible.
A trick is to remove all subplots by removing columns from Group X/Y, Wrap/Pages, apply the LineWidth and then add the columns again to the respective DropZones. But that takes some time.
Another Trick:
Send the command to all FrameBoxes of the current Graph via JSL.
But then there is still the issue when new Subplots show up (without the borders).
Anybod using Heatmaps with borders around the cells? And recommendations how to facilitate the usage?
Names Default to Here(1);
Graph Builder(
	Size( 454, 256 ),
	Show Legend( 0 ),
	Summary Statistic( "Median" ),
	Graph Spacing( 4 ),
	Variables( X( :height ), Y( :weight ), Group X( :sex ), Overlay( :sex ) ),
	Elements( Heatmap( X, Y, Legend( 3 ), Bin Shape( "Hexagonal" ) ) ),
		Dispatch(
			"Graph Builder",
			FrameBox,
			{DispatchSeg( HexSeg( 1 ), Line Width( 1 ) )}
Re: Heatmap - with borders
Maybe customization copy+paste works in this case? Right click on the graph ->Edit -> Copy Customizations. Then go to other frame and same but Paste Customizations (I think you can also broadcast this with Ctrl).
Level XIII
nice trick :)
thanks.
matth1
Hi @hogi ,
you mention one option is to:
If I don't know what the Group X values will be, how do I do this?
I presume I can do it by sending a message to the Framebox(es) something like this (where gb1 is a reference to the Graph Builder):
bordercode = "HexSeg( 1 ), {Line Width( 1 )}";
fnDef = Expr(
	(gb1 << xpath( "//FrameBox" )) << DispatchSeg( __aa__ )
Substitute Into( fnDef, Expr( __aa__ ),  parse( bordercode )  );
Parse( fnDef );
But I'm getting the following error:
Unexpected ",". Perhaps there is a missing ";" or ",".
Line 1 Column 13: HexSeg( 1 )►, {Line Width( 0.5 )}
The remaining text that was ignored was
,{Line Width(0.5)}
So I presume I'm formatting the message incorrectly. I've tried various combinations, with and without "Parse" etc but no luck.
Thank you for any suggestions!
Level XIII
fbs =current report() << xpath( "//FrameBox" );
fbs << {DispatchSeg( HexSeg( 1 ), Line Width( 1 ) )}
