shampton82
Have a new window appear next to current mouse location
Is it possible through JSL to get the location of the mouse and then have a new window open to the right of it?  It seems straight forward enough but looking through the scripting help I couldn't figure it out.  thanks for any pointers!
Steve
Re: Have a new window appear next to current mouse location
The only way that I believe that one can get the mouse position from anywhere on the screen, would be through either the JMP extension into R or Python.  Once the mouse position is returned, then JSL can create the New Window(), and then Move Window() to the desired position.
If you are using windows you could use powershell. Here is one example (might be good idea to return also number of display and not just coordinates):
powershell_variables = Eval Insert("\[Add-Type -AssemblyName System.Windows.Forms
$X = [System.Windows.Forms.Cursor]::Position.X
$Y = [System.Windows.Forms.Cursor]::Position.Y
Write-Output "X: $X | Y: $Y"]\", "¤");
//fix quotes and cleanup
quote="\!"";
escapedquote = "\!\\!"";
Substitute Into(powershell_variables, quote, escapedquote);
r = Trim Whitespace(Run Program(
	Executable( "C:\Windows\System32\WindowsPowerShell\v1.0\powershell.exe" ),
	Options({powershell_variables}),
	Read Function("text")
I have usually managed these by opening new windows on top of current window() and then calculated the location based on that.
shampton82
thanks for the suggested code.  I'm not familiar with powershell so I just grabbed your code and ran it and got this in the log:
"Add-Type : Cannot add type. Definition of new types is not supported in this language mode.
At line:1 char:1
+ Add-Type -AssemblyName System.Windows.Forms
+ CategoryInfo : PermissionDenied: (:) [Add-Type], PSNotSupportedException
+ FullyQualifiedErrorId : CannotDefineNewType,Microsoft.PowerShell.Commands.AddTypeCommand
Unable to find type [System.Windows.Forms.Cursor].
At line:2 char:6
+ $X = [System.Windows.Forms.Cursor]::Position.X
+ CategoryInfo : InvalidOperation: (System.Windows.Forms.Cursor:TypeName) [], RuntimeException
+ FullyQualifiedErrorId : TypeNotFound
At line:3 char:6
+ $Y = [System.Windows.Forms.Cursor]::Position.Y
X: | Y:"
I didn't see anything returned that I could use for the position of the mouse.  Am I missing something or do I need to do something to set up powershell?  I'm using two monitors and running the script on my primary one.
Steve
What is your version of JMP?
Are you running Windows 10?
shampton82
JMP Pro 16.0, Windows 10 Enterprise version 10.0.19044
I'm not too familiar with powershell either, I only use it when I have to. You could try running that command
directly in powershell and see if you get the same error. This is when I run powershell through commandline:
If I run the command by windows searching for powershell it seems to return similar error:
but if I run it again after the errors, it seems to return either string without coordinates or coordinates as it should.
shampton82
I could get it to work through Windows Powershell ICE but not Windows Powershell, don't know what that means but just throwing it out there in case anyone else does!
